02 zo6 timing tables in a stock truck on 93 octane?
has anyone done this? i have an 05 avalanch that i want to try this on. Stock other then a k & N air filter. I put 93 octane in the tank and now need to load the new tune, just wondering what others results were as for gas milage, towing and all around performance.
1 Post
Uhmm... no! That will add around 10 degrees of timing under WOT... and little to nothing at cruise. You can't just take a timing table from one vehicle and throw it in another. The timing has different adders in the truck than in the car...
Moderator
You need to dig a little deeper, while figuring out what
you want from the truck.
Trucks do a lot of stupid stuff, from the standpoint of
performance, in pursuit of stuff like towing fuel economy.
Like for instance holding off PE for a long while and using
a low spark advance to keep from ping.
Throw a 'vette table at that situation and you'll have a
ping fest a-comin'.
Now maybe you're prepared to live with poor towing MPG
if you're sport-truckin'. In which case you'd go and fix up
the fueling to be more like a sports car, and use timing to
match.
But it wants some thought and care, not just slap on a
random bit of "sounds like a good idea".
ping fest a-comin'.
match.
Not a good idea IMO. I made my timing tables from scratch adding where needed and smoothed it to my liking. I looked at other timing tables when I first got the software but it doesn't yield any gains. It takes time and logging to do it right.
