HELP:::what is the best way to do this swap
OK here is the deal, I have a 98 formula that used to be a A4, I swaped it to a M6 and now I am in the process of doing a 4l80e on the car. I am almost done with the physical part of the swap but I am unsure as to what I need to do for the PCM part of the car.
I was going to have a tuner load a 4l60e stock file on the PCM and just adjust for the converter....
I know I have to do some PCM splicing and add a relay in there some how (got the instructions)
any help would be greatly appreciated. I am almost to that point of driving the car.
thanks folks.
David
thanks folks.
David
Running 4L80E trans from 4L60E segment
If you already have instructions, then they would say:
- drive the 4L80E TCC PWM circuit from the 4L60E TCC signal (not TCC PWM),
- invert the 2-3 shift solenoid signal using a relay.
Those can be deduced from looking at the shift range charts and the TCC apply/release description in the HMTG books.
Those are minor wiring changes.
Edit: oh, the other Joe was being addressed, Joe is a common name...
ok I did the wiring today and found out that two of the wires are completely disconnected. I added the relay at the tranny plug as well. I was going to do it at the PCM but it seemed a lot easier down there.
over all it is not that difficult, I was just having a hard time reading the directions.
I will have the tuner delete the codes that need to be deleted when he comes to my house. I still need to measure the T56 crossmember to have it modified for this transmission, I dont want to buy a new one bc I ust purchased a tubular one for the T56 so I hope is not too many modifications that I have to do to it.
the car should be running by next week. I am taking my time bc I am back at school and my help works nights so its hard to get a hold of him.....
thanks for all who chimed in.
