Weird wiring issue.
Weird wiring issue.
So I tried to pull codes on my car and the code reader wouldnt work. I started checking wiring and I found that behind the OBD II port on my car 2 wires were pulled out of the back of it and twisted together. (I havent had the car very long) Well I untwisted the wires and re-pinned them and put them back in the port and tried to start the car and when I turned the key on, all my gauges went nuts and the car wouldnt start. I got a paper clip and put in the two holes of the OBD II port that I just re pinned and the car acted completely normal again and started up just fine. I did some research on the wires and one is a ground and the other is the "data" wire. What is going on with that?
All the gauges read crazy. Some will be maxed out and others not doing anything. The car will turn over but never crank. Also if you pull the spark plugs out and hood them up to the wire and turn the ignition on, they will just spark 1 time and its the weakest spark ive ever seen. after that it doesnt do anything. The motor will be turning over and I will get no spark. I will get fuel pressure. Its almost a total shut down of the ignition system. The parking lights will come on and stay on (including the blinkers) and just stay on and never flash. They will light up on the dash too but never blink. Its like the whole car freaks out. The second you touch the 2 wires together its like nothing was ever wrong.
Sounds like a grounds issue. If this is a stock harness there are multiple grounds on the car. Some will cause issues like you are saying. I think one of those wires is supposed to be a ground anyway and it may not be grounded when it is not together. Look at a diagram and see where it is supposed to come from. On the 4th gen cars there is are big grounds on both sides of the interior harness. The BCM does wierd stuff if they are not properly grounded....
