New motor - bogs terribly off idle, undriveable
Old 06-19-2010, 02:45 PM
388bu's Avatar
Default New motor - bogs terribly off idle, undriveable
So I had a place locally build me an LS7 and set me up with a base SD tune to get me going until they can get me in for a full tune. It idles pretty decently, but give it any gas and it bogs. No throttle response at all and the car is totally undriveable. Here are the specs:
LS7 - 12:1 CR
245 Trick flow heads
Comp 243/251 .653/.660 110 LSA
Fast 102mm intake, NW 102 Cable TB
42.5# injectors
Not running a MAF. I verified I have 58psi at the rail at idle. I also verified my TPS is at 0% when it should be. My IAC count is 50-60 or so when its warmed up, but they are up there when its cold. The IAC is wide open when its cold and it sounds like the thing could suck up a small volkswagen.
I have HPTuners, but I am pretty clueless with most of it. Ive tried going through some idle tuning procedures online, but the ones ive found assume you are running a MAF.
Any ideas on where to start with this? Thanks in advance.
Old 06-19-2010, 03:04 PM
C5kid's Avatar
Do you have a WB hooked up?
Sounds like the V table either needs fuel added or taken away. When I started tuning my car it would idle GREAT, but when you would go to pull out it would bog and just die. The AFR was taking a dive down to 15-16:1.
Tuned the VE and now she is nice and smooth.
Old 06-19-2010, 03:06 PM
388bu's Avatar
No WB, but I am seriously considering finally getting one. I may head back outside and play around with the VE a bit.
Thanks for the reply!
Old 06-19-2010, 06:07 PM
BLK02WS6's Avatar
Gotta get a wideband on there... only way to know whats going on. Sounds kinda like an LS7 I tuned recently, except the customer had a Vic Jr and 4 bbl TB. If you were using EFILive, I could help you out, but I don't have HPTuners to even look at it...
Old 06-19-2010, 08:05 PM
edcmat-l1's Avatar
Do you know how to run a scan log? Can you do that and post the log and tune? A WB is not critical to just get the thing to run half way decent.
Old 06-19-2010, 09:01 PM
388bu's Avatar
Awesome man, I really appreciate any help you can provide. Here is a scan that I just ran.
Basically I took the base tune my builder gave me and added 40% fuel across the whole range to the VE table. This was basically the only way I could make the car half driveable. Crazy amount of fuel, I know. Oh and also, I disabled CL completely because that seems to help.
Ive attached the tune I used in case that helps as well.
Thanks again!
File Type: hpl
File Type: hpt
Old 06-20-2010, 04:16 PM
edcmat-l1's Avatar
VE was kinda ugly. Displacement was not adjusted. Try this one out.
Use your histograms VE/STFT to dial in the VE further, but this should get you pretty close.
Base LS7 tune.EH1.hpt
Old 06-20-2010, 04:46 PM
388bu's Avatar
Thumbs up
Awesome! Thanks so much! I will give this a shot as soon as I can.
Yeah, I noticed displacement wasnt right, but I just assumed it really didnt come into play anywhere.
Old 06-20-2010, 07:30 PM
388bu's Avatar
Just thought id mention that the car is probably running its best so far! You definitely helped a lot. Again, cant thank you enough for helping me out here.
I just need to sit down and analyze the logs a bit, but it seems like its leaning out past say 10% throttle. Ill likely just buy a WB and tune from that.
One thing I noticed is that the idle wont really come down very well now. Any thoughts on that?
Old 06-20-2010, 09:09 PM
edcmat-l1's Avatar
All I did was set the displacement, and plug in a VE table that was close. Any further help will cost money. Sorry to be that way, but I do this for a living. Sometimes I throw out free help, but I can't tune your whole car for free.
Old 06-20-2010, 09:40 PM
388bu's Avatar
Thats understandable. I certainly wouldnt build you a website just because you asked nicely.
Thanks again.
Old 06-21-2010, 07:00 AM
edcmat-l1's Avatar
Thanks again.
LOL. Pretty please?
Quick Reply: New motor - bogs terribly off idle, undriveable
