Formato's Florida Tuning Schedule for July:
LS1TECH Sponsor
Hello folks, here is the travel schedule for Jeremy Formato tuning (and intake/tb porting and install) through out Florida for the month of July. Of course if you are in the Tampa Bay area or wish to travel to us, we can schedule this as well for dates other than these listed. Just give us a call at 813 476 7364 or Jeremy on his cell at 813 495 8778.
July 7th - Gainesville
at:
Rollins Automotive
9430 Northwest 13th Street
Gainesville, FL 32653
(352) 335-7223
July 9th - Orlando
at:
Cor-Vette Masters
8615 U.S. 17
Maitland, FL 32751-3306
(407) 831-3990
July 15th - Ft Myers
at:
Aftermath Performance
2940 Hanson Street
Ft. Myers, FL 33916
(239) 939-4649
July 22nd and 23rd - South Florida
at:
Rage-Tek
2021 Southwest 70th Avenue
Davie, FL 33317
(954) 915-0016
Please call us at 813 476 7364 to schedule a date and time to have your vehicle tuned. We do require a $100.00 deposit to secure your spot. We accept Visa, MC, and American Express or you can Paypal at:
fastprom@tampabay.rr.com
The intake and throttle body special will be in effect for all these locations as well. Here is a link to the special:
https://ls1tech.com/forums/corvette-...cial-back.html
For those that are not familiar with Jeremy Formato tuning, here is some information:
The cost of dyno tuning is $400 + $85/hr for the dyno. If you are just looking for a street tune he can also do that for $300 w/ WB o2. We work very hard and are extremely thorough to make sure every vehicle is perfect and you are completely satisfied.
We are here to optimize the tuning of your LSx based vehicle. We also offer power packages that will meet your performance goals. We help you select the best parts that will give the best bang for the buck and make the right combination custom tailored for YOUR application. We are extremely thorough and precise in our tuning and go much farther into the code than other tuners. We tune the vehicle from idle, through wide open throttle, and as aggressively as you want to optimize the vehicles full potential for power and fuel efficiency without sacrificing any longevity. We inform each and every customer of exactly what is going on with the vehicle and explain what certain tables do and how to improve the vehicle. We have ported throttle bodies and intake manifolds with repeatable Dyno proven results. We try our best to offer the most aggressively ported manifolds money can buy. We test on the Dyno as well as the street to make sure everything is safe and dialed in 100%.
With our custom tuning we address many of the limitations the factory has placed on the vehicle. GMs minimum of 91OCT fuel allows us to gain power if we are using a fuel of greater octane. Later model vehicles lose a vast amount of power as they heat up, we combat this and make them much more consistently powerful. You don’t have to be racing to enjoy what we can do for you. Daily drivers can still have a bit more fun on your daily commute . If it’s the pesky 1 to 4 skip shift, the hot coolant temp, lack of power, fuel economy or throttle response, slow or soft trans shifts, shift points, WE CAN HELP.
The car will accelerate much smoother and effortlessly, it will have sharper response and more power when we optimize the tune.
With a ported throttle body, you will feel greatly improved throttle response and in the bottom end/mid range a strong seat of the pants increase. Many liken the difference to taking about 350lbs out of the vehicle. It truly makes the car much more fun to drive. Our Manifolds are very thoroughly ported not only in the runners but also much of the plenum and TB flange are enlarged in order to support more airflow from idle, thru the upper RPMs. The larger the air reservoir is, the less likely it is to deplete the greater volume in the upper RPMs. Hence the difference of the '00 LS1 intake vs the '01 LS6 intake, a small plenum volume change gained 10RWHP and 10RWTQ.
We also port LSX FAST manifolds. We have been modifying our LSX manifolds more extensively than our competitors and found more power in certain areas that others do not touch. We open the TB flanges as well as reshape the bell-mouth port entry and increase plenum volume, resulting in a minimum average gain of10RWHP and 10RWTQ avg. gain over non ported FAST's.
LS1's and LS6's are not ported, as we have seen no measurable gains in porting these intakes, the runners and plenum are thin and without obstruction. If an upgrade is desired we suggest the FAST LSX manifold for ’01-04 model years or an 01-04 manifold for 97-00 model years.
We have been tuning for over 10 years and have tuned literally thousands of LSX based vehicles from stock to 1100HP. We are based in FL but travel all around the country Dyno tuning and porting. We know what it takes to make a ROCK SOLID COMBO with best TQ and smoothness. Please feel free to call us and ask ANY questions basic to advanced tough questions. If we don’t know we will find out. We are honest and will do our best to make you happy with all the work we do!
at:
Rollins Automotive
(352) 335-7223
July 9th - Orlando
at:
Cor-Vette Masters
8615 U.S. 17
(407) 831-3990
at:
2940 Hanson Street
Ft. Myers, FL 33916
(239) 939-4649
at:
Rage-Tek
Davie, FL 33317
(954) 915-0016
LS1TECH Sponsor
We still have plenty of availability to schedule for all locations, so if anyone needs tuning and or intake/tb porting done, please don't hesitate to call us at 813 476 7364.
Thank you
Dan
Fasterproms
Thank you
Dan
Fasterproms
LS1TECH Sponsor
Schedule Update:
Dates added:
July 27th - Gainesville
July 29th - Orlando
Also, there is still a space or two available for S. Florida this Thursday and Friday, just give us a call to schedule.
Thanks
Dan
Fasterproms
July 29th - Orlando
Thanks
Dan
Fasterproms
