ECM Reflash questions.
Old 06-30-2010, 01:08 PM
radiowaves88's Avatar
Default ECM Reflash questions.
Hello,
I am transplanting an LS1 from a wrecked 2000 Camaro into a 1946 Chevy truck streetrod project. I bought a Painless Performance complete chassis harnass which intergrates the LS1/4L60E into the wiring. With the harnass purchase came a ECM reflash from Painless. There are some questions on the reflash form that I can't answer. First, they want to know what thermostat I am using along with the fan on/off temps that I would like. What would be a good thermostat temp to use and what should the fan on/off temps be? Also, they want to know what DTC codes that I want deleted. I know about the rear O2 sensors and the security, but what other codes should I have deleted? If you know of anything else that I should be aware of feel free to let me know.
Thanks, Al.
Old 06-30-2010, 01:11 PM
Joshiedoom's Avatar
i would run a 180-185 thermostat, no clue about the fans,and i would delete VATS, EGR, AIR, and the 02 sensor codes. Subscribed
Old 06-30-2010, 02:41 PM
poconojoe's Avatar
Which Hanover, PA do you live in?
Old 06-30-2010, 02:48 PM
LS1TECH Sponsor
mikey's Avatar
You can send the PCM to me and I can load a base tune in it. Or take a drive here, it's not really that far.
Mikey
Old 06-30-2010, 02:58 PM
poconojoe's Avatar
Mikey
Do you know where he lives?
There are 4 Hanovers listed in PA
That's why I ask him which one
Old 06-30-2010, 03:10 PM
I live in the one in south central PA near Gettysburg. The reflash from painless is part of the price of the harnass that I bought, so that is why I'm sending it there. Al.
Old 06-30-2010, 03:11 PM
Frost's Avatar
If they know what they are doing, you shouldn't have to tell them which codes to delete (assuming you provide setup details).
Old 06-30-2010, 03:36 PM
poconojoe's Avatar
Yea, I know what Dennis's (Painless) deal is, that's a nice harness, but pricey. You had to live at the one furthest from me. Closest to Mickey, though. If you're not sure, which DTC's to turn off, just let them on, and if they light the light, I'll stop by sometime and turned them off, for free for you. I'll end change you fans temps if they cycle too often or it runs too hot. Of course I'll bust on Dennis next time I see him. I get down that way every so often. I try to get to the Renne faire at least once a year and I like going to the Rod show at York. Most of the guys i do swap PCMs for use 180 on 175 off for fan #1 and 185 on and 180 off for fan#2 If you're looking for the real tune later, I've not heard anything but good things about Mickey
Old 06-30-2010, 03:37 PM
By setup details, I assume you mean tire size, rearend ratio, idle RPM etc. Yes, I have provided these. At the bottom of the form, they have a space to "List all other DTC deletes". That is my basic question. Al.
Old 06-30-2010, 03:42 PM
Thanks Joe, what degree thermostat would you use? Al.
Old 06-30-2010, 09:40 PM
poconojoe's Avatar
Personally I like 180's some places have 184 or 186's instead. Gen3's are fairly cool running motors, compared to a 1st gen, but I don't think I'd go below a 180 By the way most factory stats that I've pulled were 195
Old 07-01-2010, 09:44 AM
OK Joe, so if I go with the 180 thermostat, I should have the fan on/off at 180/175 right? Thanks for your help, Al.
Old 07-01-2010, 10:51 AM
poconojoe's Avatar
That what it seems most of the swaps guys I did PCM's for, with are doing, so I'd go with it. Seriously if you have some DTC or setting issues that need to be addressed, later on, I'll stop past
Old 07-02-2010, 12:11 PM
OK, thanks Joe.
Quick Reply: ECM Reflash questions.
