mulitple misfire ses light set an flashing but car runs fine?
for some reason my ses light is flashing in my 99z28 and it comes back as a multiple misfire code but my car runs fine. anyone know what this could be?
I believe the PCM only detects MM by sensing quick changes in crank speed at idle. In other words it's looking for a smooth rotation of the crankshaft, not like when there's a miss or idle roughness caused by a hot cam. A cammed car often sets MM if idle is low. You can work around this by raising the idle. If no cam, find the misfire.
The code reader you have is just that, a code reader. A true scanner will let you see the actual real time engine data to help you diagnose a problem.
A scanner will show you the engines misfires as they are occurring, cutout one cylinder at a time, etc so you can pinpoint which cylinder is having the issue.
