open loop when?
Old 01-17-2004, 10:11 PM
gonzo 6.2's Avatar
Default open loop when?
At normal operating temp i go into open loop at near 50% throttle position. It seems it used to be only at WOT and maybe 90% throttle position.Looking for anyone that may know why. The vehical runs fine and the same since the mods just recently the towing mileage dropped and the towing power seems off. Power not towing seems as strong as always and driveability unchanged ,swapped out throttlebody w/TPS,put back stock intake,swapped map sensor,didnt change at all.
Old 01-17-2004, 10:33 PM
jrp
SN95 Director
jrp's Avatar
Open Loop Operation determines the air/fuel ratio based on predetermined tables stored values. This happens when the low coolant temperature is low that the PCM will trigger fuel enrichment outputs to act like a choke for cold-start and warm-up situations
Old 01-17-2004, 11:17 PM
gonzo 6.2's Avatar
When running at operating tempature what would cause the PCM to go into open loop near 50-60% throttle position?When it wasnt doing that prior
Old 01-27-2004, 11:52 PM
BigTex's Avatar
Calculated vehicle load?
Old 01-30-2004, 12:56 AM
deezel's Avatar
Did thiis begin after the new tune? Could be Ed lowers the WOT enable %tps in his tune...?
