What MAF?
1 Post
For the short time I ran one on my 408 (went SD), I used a GM 85mm that I got with the adapter harness from Pace parts. It was the one that was not calibrated for an F-body (I put it on and tuned it right away).
108100 harness number you need if you go with the 85mm. on the 100mm heard there a pain to tune. read alot of people are putting screen or honeycone in there 100mm and it helped out alot. just make you own 4inch tube and a ls7 maf. $53 on gmpartsdirect for the maf 9705 spectre 4inch housing with maf i think would work havent tried it. also 108125 for the connector for ls7 to ls1
http://www.hptuners.com/forum/showth...ighlight=100mm
