new motor swap wont idle right, help?
Old 07-17-2010, 06:32 PM
6LiterHawk's Avatar
Default new motor swap wont idle right, help?
im just about finished with my lq9 swap into my 2000 firehawk, the car turns over fine, it just wont crank until you give it some gas, same with the idle, i can keep it at a low idle with the throttle, but when i let off it dies, the motor is cammed, 248 duration and 578 lift on a 112 lsa. ive heard about possibly enlarging the hole in my throttle body valve, wondering if its a good thing to do. any help would be greatly appreciated. thanks
Old 07-17-2010, 11:17 PM
SoCal01z28's Avatar
what kind of throttle body/intake? it's also important to know what your iac counts are. If you have a set screw, I'd start there by bumping it up a little.
Old 07-17-2010, 11:23 PM
Restricted User
1BAD_LS1's Avatar
get it tuned and get a CASE (crank position relearn) done on it.... your problem will be solved!
Old 07-17-2010, 11:56 PM
6LiterHawk's Avatar
yea i messed with the set screw a little, i have the ls6 intake and throttle body, 28# injectors, definitely dont have the money for a tune right now.
Old 07-18-2010, 07:44 PM
BLK02WS6's Avatar
Well, you need a tune... you can't just throw a cam in and all is well. I will never understand why people mod their cars if they don't have the money for a tune...
Old 07-18-2010, 09:23 PM
6LiterHawk's Avatar
well i did have money for a tune but some stuff happened, i knew it would need a tune, im not stupid, i just wanna drive it, so i guess im just gonna up the idle until i can get it tuned.
Old 07-19-2010, 09:53 AM
SS1875's Avatar
Well to be honest, you are being stupid if your planning on driving it without a proper tune for doing so. That leads to more problems and money down the road...something at this point you don't have.
Be smart...wait until you have the funds to do it properly.
Old 07-19-2010, 10:21 AM
BanditDave's Avatar
Yea bud, PLEASE listen to what these guys are telling you. That is a significant jump and cam size...you could very easily go lean and rattle the engine...game over. Then you'll have to start all over.
I KNOW how bad you wanna drive the thing, but sit on it a little longer until you can get her tuned properly. Not only will it be a much safer motor, but it will drive WAY better than it would if you drove it now. You will get a lot more enjoyment out of it.
Good luck with your build.
Dave
Old 07-19-2010, 04:00 PM
6LiterHawk's Avatar
i know, ive just been waiting on it to be ready for quite a while now. i definitely dont have the money to mess up the motor and start over though. will wait for a tune, anyone know of anywhere around dallas i can get a tune for relatively cheap.
