Help I have power everywhere but car wont start????
Car is 2002 camaro z28 115k miles stock except intake, problem is i have power every where but when i go to turn the key aboslutley nothing happens wont turn over. I have already replaced starter relay, ignition switch, neutral safety switch, and power still not going to s terminal of starter, running out of ideas, anything helps..
find a buddy or gf or something or a dog if hes smart enough and have them sit in the car. Get underneath with a hammer and GENTLY ! tap the starter while the person cranks the car
Pull the starter relay out with the key on jump 30 & 87 on the relay block
the engine should at least crank. If it does not start it could be a passlock
problem.
Check for voltage @ 86 with the key in the cranking position. Wire from 86 goes
back to the BCM and no power there could also be passlock
problem.
