Tune LS1 pcm for LS2 knock sensor setup
I threw a 404 ls2 in my car and I had to relocate the knock sensor on the side of the block. I don't believe I have seen a single degree of knock anywhere and I am at a good amount of compression, 11.5ish.
What do I have to do to make sure they are picking up knock correctly?
I have about 23* of timing at full throttle, should I just jack the timing up like crazy just to test if it will trigger some KR? if so, how much should i raise it?
As long as you set up the knock sensor type, then it should be fine. You would just have to adjust the sensitivity UP a little to make it hear it better if on the side of the block.
And Salah, your airport is crazy! I have never had to be bussed to the main terminal before in a different country like that. Nice country though. I had fun.
