need help, looked for everything, plz help
ok so i did a cam swap, pulled the motor out painted the bay, sanded all the grounds, cranked it over an started but no tach, tach runs off the cps. changed that nothing, checked the grounds on back of head nothing.
could this cut wire shorted out an be my problem?
i washed my bay before relizeing it was exposed.
how do i run a new wire, it goes from pcm to ....
any help will work plz!
Okay so im geting a tach out singal. I hooked up a 2in tach to that white. Ground. N pos an the mini tach works, i have a bwd cam sensor gonna swap it for a acdelco.
Could the tach just have died?
