01' Camaro Engine/pcm in 98' Trans Am
Old 08-08-2010, 06:53 AM
MADCOW's Avatar
Default 01' Camaro Engine/pcm in 98' Trans Am
Im about to swap the motor/trans from an 01' Camaro SS into a 98' Tran Am roller. Im just looking for any tips or heads up of problems I may run into with the pcm and harness. Any help would be appreciated. I want to use the 01' camaro pcm/ harness but not sure if it will be a simple swap into the trans am. Ive read that I may have problems with the guage cluster. Will I have to put the 01' Camaro cluster in the Trans Am? Also what about the Trans Am headlight wiring?
Thanks in advance
Old 08-09-2010, 04:01 PM
MADCOW's Avatar
Does anyone have info on this? Im just wondering if Ill have to put the camaro guages in the trans am and what about power to the flip up headlights
Old 08-09-2010, 05:01 PM
eseibel67's Avatar
The experts must be on vacation. I'll try my best.
The headlight wiring will not be affected since the circuitry is unrelated.
Althought the 01 PCM is a better setup for tuning than the 98, swapping the 01 engine/trans into the 98 body/PCM as is will introduce fewer variables. If going this route, you will need to use a temp sending unit from a 98.
Also, the 01 will not have EGR, so you will have to tune that out. Certainly you don't want to search for inferior 98 intake/exhaust manifolds to accomodate the EGR.
Hopefully a real expert can give you better advice.
Old 08-09-2010, 05:38 PM
MADCOW's Avatar
Thanks. That's good to know about the headlight wiring. I plan on using the pcm from the 01' so it stays with the 01' motor. I plan on starting the swap this week so Id like to be prepared for any roadblocks.
Old 08-09-2010, 07:06 PM
bigboykilroy's Avatar
Ok, Im a 98 conversion guy here. IF you are using a 98 body harness and cluster, then the easiest thing to do is use a 98 engine harness and repin in out. You CAN use the 99+ engine harness but you will need to run wires from importanty sensors to the cluster directly. PM me and I will help you thru it. People will say alot here, I have just swapped out the 98 pcm for a 2002 pcm, so my install is very fresh.
Old 08-09-2010, 08:43 PM
9-Second Club
Ed Wright's Avatar
It won't do one thing better with an '01 PCM versus the original '98 PCM. Why in the world would you not simply put it in and plug it in and drive it? Your making a ton of work for nothing.
MADCOW's Avatar
Thanks. I appreciate the offer of helping me. Im thinking the easiest way to do this may be to use the guage cluster from the 01' camaro as well. This way everything stays together. Any reason that wouldnt work?
Old 08-09-2010, 08:47 PM
9-Second Club
Ed Wright's Avatar
Why in the world would you do all that?
Old 08-09-2010, 08:56 PM
MADCOW's Avatar
The 98' PCM isnt the original for the motor Im putting in the car. I totalled my 01' Camaro SS that only had 15K miles on it so I bought a 98' Trans am roller. I simply want to swap everything over. Whether or not I use the 98' or 01' pcm does not matter to me about the amount of work required. So your saying run a 98' pcm on an 01' motor?
Old 08-09-2010, 09:02 PM
9-Second Club
Ed Wright's Avatar
Yes, run the '98 harness and computer with the '01 engine. Same injector flow rate. Shut the EGR off in the '98 PCM and use the '01 spark tables.
The '01 intake likes a little less spark advance from 4000 RPM and up.
If fuel is good enough in your area you may not have an issue there either. Do you have emissions testing where you live?
Old 08-09-2010, 09:16 PM
MADCOW's Avatar
I didnt think running the 98 pcm on the 01 motor would be a simple plug and go without tuning. Ive been out of the scene for awhile so I no longer have a way to change the spark settings. Plus we do have emissions testing here so Ill have to run through inspection after I get it running.
Old 08-09-2010, 09:21 PM
If you have all the 01 camaro's harnesses you will need to use it all. You have 2 options 1 easy 1 more work but i think better.
None of the 98 harnesses to 99+ are plug and play interchangeable.
Option 1 easy:
Since you have a 98 roller, you can use the 01 engine and trans with a 98 pcm use all the harnesses that are in the 98 roller, change the oil pressure unit on the 01 engine (98 2 wire 99+1 wire), temp gauge sender on the engine (98 3 wire 99 2 wire). Plug everyting in and you are done.
Option 2 Harder:
Gut the 98 roller, move over and install all your 01 harnesses (Engine Harness, Dash/interor body Harness, Engine Bay Harness), drop in the engine and trans and have fun.
Now for just stock the 98 is fine, if you have some nice mods, cam heads, etc, a 99+ pcm will be easier to tune and will run better. I know I just did it to mine and it was worth the work in my opinion for my supporting mods. (I just repinned out the 98 pcm harness at the red and blue connectors to use a 2002 pcm.)
Old 05-31-2017, 10:55 PM
taws6ali's Avatar
Option 1 easy:
Option 2 Harder:
Hey bud just bought a 98 roller with 01 pcm installed an ls3 with 99+stylesebsors "my fuel level , oil pressure and temp guages arent working" i see the temp sens had a 2 plug going into a 3 plug adapter any help to get fixed us greatly appreciated
Old 06-01-2017, 12:40 AM
Received 3,019 Likes on 2,350 Posts
Replying to a 7-yr old thread....
Quick Reply: 01' Camaro Engine/pcm in 98' Trans Am
