my cam only car dont have street manners ...
i noticed that my tuner disabled the front o2 sensors !!
is that SD tune ? maf still in place .. !
also car is running rich and idles like crap+ bucking while a/c on .. is that a right tune ?
& is that normal for Cammed cars ?
cam specs in my signature .. help
Not a correct tune. Do you have front O2's installed? Did your tuner disable closed loop?There is usually a 'closed loop enable' field based upon coolant temp. If it's set real high, then the car never goes into closed loop. Not being in closed look prevents the computer from making fueling adjustments.
SD would be ignoring the MAF signal (which corresponds to a measured amount of ingested air) and relies completely upon tables in your calibration.
If you know that the tuner disabled your O2's, does that mean you can read your calibration and post it here?
after my first tune ..car started to throw o2's codes ..then i went back to the tuner .. he mentioned that o2's must be disabled for better idling but noting changed since .. running rich at idle and bucking on low rbms ..
i replaced my plugs & wires ..
cleaned my maf and TB
and still same issues..
