air bag light, odometer rest
just the other day, my air bag light came on and odometer reading reset to 0.0, no codes came up yet, i changed the battery and still the same thing, the cluster rpm etc do not bounce at all. does any know were i should be looking to correct these issues... both issues came up at the same exact time.....
2002 camaro with 8,000 miles cluster read....
I'm guessing it's cluster related too. The '99 cars reset the odo when battery voltage was low - GM TSB fix was to replace the cluster, but good battery makes it go away (air bag light wasn't mentioned, but sometimes the gauges would sweep on startup). Shouldn't be happening on an '02 with only 8K miles. Sounds like dealer time, they can test the cluster.
Ive had airbag and ABS both come on under a bad battery situation.
Replaced it and everything was happy.
Had another that did same with a good battery. I looked closely at the (+) cable and it was corroded inside the terminal.When I wiggled the cable it looked like it had dandruff inside the insulation.
I cleaned it real good,recrimped the terminal and all is good.
its not the battery, i just installed a new one and still the same problem, read the air bag module and got a B1001 code, and once i was reading the codes the odometer display was displaying error that i never seen, i guess i am going to check all the positive and grounding conections first........
if it is the cluster and purchase a good used cluster then how would i change the millage back to 8,000........................i just probally better take it to a dealer.................what do you guys think...............
took it to a gm dealer today,,,, he said that the car is to old, 8 years and it sits for long period of time........ and it would cost me around 2 thousand to diagnose... WTF........... hes got to be crazy. i took the car right out of their...............i have a feeling its the cluster,, car runs great and the lights etc runs.....i am going to by a cluster on ebay and take my chances, again, how do i put back the 8,000 miles on a good working cluster........if that the problem, or were can i buy a new cluster.....
okay got one issue resolved, the milage reset,,,, was the cluster, took a dump. i got a used one and pluged it in worked great... now its the air bag, were can i rebuild my cluster or change my milage back to its orginal, i know milage is stored in the cluster......got to be a way....
