WTF!!! lost .5 sec. off my ET after upgrades.
Old 08-12-2010, 09:30 PM
t72ss402's Avatar
Default WTF!!! lost .5 sec. off my ET after upgrades.
Ok I had a cam(228/232 588/595 114lsa), intake(96mm typhoon), TB(95mm PTM), and set of LS7 injectors(42#). And had it tuned.
Now I went from running a 12.45@111mph to 12.91@114. I know that I did pick up in speed but not that much, this setup is on a LS6 long block. I have a 4L80E(3000 stall), and 3.42 gears in a 12 bolt. Ran the same setup with the stock LS6 with the 12.45 ET. WHAT GIVES?
Old 08-12-2010, 09:36 PM
LaBLKv6Z's Avatar
Probably the weather/climate.
Old 08-12-2010, 09:37 PM
HioSSilver's Avatar
Hard to beat a stock ls6.....read the sig
Old 08-12-2010, 09:54 PM
MUSTANGBRKR02's Avatar
What was your 60'? You picked up MPH so with a slower ET i would say your 60' is slower.
Old 08-12-2010, 10:58 PM
HioSSilver's Avatar
1.9.....did it on 18's
Old 08-13-2010, 06:01 AM
BLK02WS6's Avatar
You picked up 3mph, so that's about 30rwhp gain... Your 60' obviously had to be worse than the earlier run. Sounds like its time to stop spending money on power and start spending some to get it to the track...
Old 08-13-2010, 06:34 PM
t72ss402's Avatar
Ya I did lose some on my 60ft, cant remember exactly what it was.
Heat hell ya it was hot, that could be alot of it.
One of my friends that helps out with most of my work says that it may just need to be geared down now. 3.42 to 4.11 would be a big change. You guys have any input on this?
Old 08-13-2010, 06:58 PM
Fix what you have before you throw more parts on it.
Old 08-13-2010, 07:41 PM
djfury05's Avatar
what intake did you have on before? going to a bigger intake most times looses some low end torque if you had the LS6 intake on before.. that's what happened to me also.. gain HP lost little bit of TQ, but it pulls way harder once you get it in the powerband
Old 08-13-2010, 10:27 PM
t72ss402's Avatar
Yes I had the LS6 onit before. So looking at maybe doing a gear swap now.
Old 08-14-2010, 02:12 AM
Johnv's Avatar
Diff gears will get you into the happy spot of that cam quicker.
But you need to work on your suspension and tyre setup to get the best out of the extra power.
Old 08-14-2010, 09:22 AM
t72ss402's Avatar
My suspension is already setup. Koni adjustables up front, bilstien in the rear with bmr everything on the rear. front is all still stock exept the koni's.
Old 08-14-2010, 10:40 AM
Frost's Avatar
doesn't sound like it with a 12.9 @ 114MPH... what is that, like a 1.90 60'?
Old 08-14-2010, 11:01 AM
t72ss402's Avatar
No even worse, it is a 1.99 or 1.98. Cant hardly read it. It is so hot outside that it erased the numbers.
Old 08-14-2010, 03:33 PM
BLK02WS6's Avatar
Is it lowered with no LCA relocation brackets? That is a horrible 60'...
Old 08-14-2010, 09:52 PM
t72ss402's Avatar
No not lowered at all. I dont have Adjustable LCA. The car is hooking good. No tire spin. Tire pressure is about 20-22psi.
Old 08-14-2010, 10:29 PM
Frost's Avatar
What are you doing then, leaving off idle?
Old 08-14-2010, 11:27 PM
flintwrench69's Avatar
Hard to believe a stock LS6 runs 11.6 @122 with 1.9 60s in an Fbody.
Old 08-14-2010, 11:49 PM
onefastmx5's Avatar
If its hot as hell, that will definatly affect ET.
Old 08-15-2010, 06:45 AM
BLK02WS6's Avatar
He picked up MPH - it's making more power up top - nothing to do with the heat...
If it dead hooked and still lost from the 60', then you need to log it at the track and find out what's up... your losing a lot of power down low. Might be knocking... I've seen plenty of cars that didn't knock on the dyno cause they were strapped down - get to the track and launch it and exhaust rattles, etc can cause it to knock off the launch and it lays over... That cam should not lose power down low over the LS6, so something is up.
