questions regarding vats and bcm.
Old 08-15-2010, 11:12 PM
scj
scj's Avatar
Default questions regarding vats and bcm.
my question is, if i have vats deleted off the pcm, can i run a different bcm in order to fix bcm problems that i'm having with the car without it affecting anything from functioning?
Old 08-15-2010, 11:40 PM
MontecarloDrag's Avatar
The engine will run good even with no BCM as long as VATS is disabled and all electric circuits are in place.
Old 08-16-2010, 12:13 AM
scj
scj's Avatar
well i'm having all kinds of issues with my bcm module, vats is disable on my pcm tune, so i was thinking i could just get another bcm from a junk yard, and hope for it being in better working condition that my current one. so with what you said, this will work?
Old 08-16-2010, 12:48 PM
If the BCM is for the same vehicle and works good, you will be ok. You only need to marry your keys to the new BCM to re-enable VATS
