recently changed plugs & wires now getting code
Old 08-20-2010, 04:57 PM
Chaos07's Avatar
Default recently changed plugs & wires now getting code
I changed my Plugs n Wires yestruday and today i got the SEC light so i hooked it up to a Diagnostic reader n it said P1637, P0137, P0157..i know ive gotten P0137 n P0157 before but the 1637 is new to me any ideas?
Old 08-20-2010, 05:01 PM
Chaos07's Avatar
oh ive looked it up also so but the reader said it was ECM/ABS blah blah blah but on here it says L circut soemthing.....any idead what caused it to come up...i mean the car runs like a champ
Old 08-22-2010, 09:04 AM
Darkman's Avatar
That collection of codes could theoretically mean failed O2 snesors and failed alternator. However, since they have occurred following a plug and wire change, the more likely cause is loose connecotrs and/or grounds. Recheck all the connections you may have deliberately or accidentially disturbed while changing the plus and wires including any grounds in the vicinity (eg. on the side or back of the cylinder heads) . Finally, those codes can occur from water intrusion into the affected connectors if you cleaned the motor during all this.
