Deleting BCM help on a 96 firebird please.
Hello. I am running a 96 v6 firebird with a Carb'd small block chevy. I deleted the whole pcm and wiring harness excepting for the one wire that comes from I believe the bcm that activates the starter relay. That is the only wire I left.
I am wondering what all the bcm control's and if I need to keep it. The car has power windows and locks. The cooling fans are stand alone and none of my gauges work. I don't figure I need the air bags either they probably dont work.
What kinda things could I run into if If I decided to remove the BCM. I think the worst thing I could run into is the windows lights and windshield wipers wont work and I don't want to lose or rewire any of them.
Any suggestions??
Any suggestions??
Any suggestions??
Any suggestions??
I removed the pcm not the bcm. Was just wondering if anyone was deleting there bcm or not. I have the correct keys and what not and have no problem with it starting. Think I might just remove the air bag and control module and a couple other things. Ill leave it alone.
