Speed Density question
I run open loop speed density because I like the throttle response and flexibility.
But, I think closed loop is probably best for most applications - usually, you are going to get better fuel mileage with CL.
With that being said, most setups are perfectly fine with MAF CL as well.
I run CL, just thought it would be nice to have cover my butt for any little changes in weather, gas, etc....
I turned CL off a couple of times and my AFR is still 14.3-15.1 when I am running OL.
I try to do all my logs at the same time of day etc with the car fully warmed up to keep atmospherics consistant. I also filter the data quite heavily to keep the transient errors to a minimum.
Once the VE table is dialled in with this method, any deviation can be attributed to other factors & the necessary tables tweaked.
1 Post
If your VE table is a moving target, then you have something else going on... You are in OL for tuning right? And have STFT for idle set to disable? Clear all learned trims before logging... a couple passes on the table should bring it right in.
what I mean is if you look at your histogram you are logging averages. If you look at the highs and lows you can see the swing. I guess what I'm asking is can that swing be reduced? LTFT have been turned off long time ago and cleared and I am in OL.
1 Post
As you correct it using the averages, it will make smaller swings... It also helps if you make smooth throttle transitions while you are logging. It's kind of an aquired feel to do it and get good data quickly. And after tuning so many cars, you get to know what the VE should look like and how to get it right quickly... Don't know if HPTuners has filters, but they can help to filter out data from quick throttle movements and such...
