I need help for my heads and cam...
It has a misfire code and dumping fuel when its idling.
Nothing wrong w/ the O2 sensors, they're brand new but somehow the DS is either lazy or staying btwn 300 mv to 700 mv at idle... the PS is osculating up and down real good though.
Cam is 222/226 EPS cam w/ stock 243 heads, supporting mods of course and typical pulley/full exhaust/LS6 intake/28.8lb inj/lid/ported MAF/FRA and FROST bolt on tune.
I'm not asking for a hand me down tune however I am asking for help to get this misfire fix and get the O2 sensor working good again because it was working well before the heads and cam swap.
I have HPTuners PRO so if you can just point me to a direction to correct my misfire as I think its a false misfire due to the cam change and hopefully it'll fix my O2 sensor problem.
Once I get that done I'll press on and get a real dyno tune once I get a day off or two.
Thanks.
Thanks.
