HPTUners with windows 7
Old 09-30-2010, 10:23 AM
Trunion King
bene's Avatar
Default HPTUners with windows 7
I cannot get my HPTuners started w/ my new laptop. It says COM port not recognized or unauthorized or something.
Old 09-30-2010, 10:25 AM
cutlass_455's Avatar
32 or 64 bit W7?? Pro version??
If using Pro you might be able to use the Win XP emulation mode and get it in that way.
Old 09-30-2010, 10:29 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
Usually it is due to the drivers not properly installing. Go into your control panel/device manager screen. You should see both drivers with an exclamation point or a question mark beside them. Go into the HPT CD Rom disk and save the drivers to a folder/desktop. Go into those 2 drivers in the device manager then and manually install the driver from where you saved it to.
Or you can read this thread lol
http://www.hptuners.com/forum/showthread.php?t=5228
Trunion King
bene's Avatar
Windows 7 home premium.
Old 09-30-2010, 11:56 AM
Jim_PA's Avatar
Yep, what he said. It runs fine for me on Win 7 pro 64bit after following instructions.
Old 09-30-2010, 12:59 PM
LS1TECH Sponsor
foff667's Avatar
Yeah if you are running 64 bit drivers you must use the signed drivers found in the help file or in the thread posted.
Our next batch of disc's will have the signed drivers, our current disks only have the unsigned ones that don't work well on 64 bit operating systems though.
-Bill
Old 10-01-2010, 02:29 PM
Trunion King
bene's Avatar
Fixed! Thanks fellas! fabulous.
