What Wideband O2 for EFI Live v2?
1 Post
Personally, I like the LM-2... and whichever you decide on, I would use a serial cable vice the analog - much better signal and no grounds to worry about causing the readings to be off... here is where to get them:
http://www.taquickness.com/taqcables.htm
Definitely take advantage of the serial connection the V2 has.
Anything with serial output and the ability to calibrate the sensor.
Supported Serial WBO2 Controllers for EFILive V2
