LC-1 and cobalt AFR gauge wont read right help!
So do you know what volt values i need to set the LC-1 at so that the cobalt AFR gauge will read right? The lc-1 info says that the analog 2 brown wire is setup for a autometer type gauge already but it does not seem to matter if i hook it to the analoge 1 yellow or 2 brown wire it still does not rear right. analoge 1 just jumps all over the place and lites up most all the led lights and 2 just stays rich and does not move. I did have to kill power to the LC-1 when wiring the cobalt gauge.....would i need to re calaberate the lc1 be doin teh free air set thing again? Also now when i try and hook up the laptop to get a data log it wont work. When i try to connect it just says no real time connection can be made bla bla bla. Have any ideas?
