How do you jump from EFI Live to HP Tuner?
I have an '02 LS1 motor which was tuned with EFI Live. I want to use HP Tuner to retune the car.
However HP Tuner can't communicate with my PCM.
Have a coupla questions...
#1 Why can't HP Tuner "talk" with my PCM?
#2 Do I need to go back with EFI Live and reload a stock map?
#3 How do I get HP Tuner to work here?
TIA!
TIA!
Just talked with Texas Speed and Performance, they said that EFI Live recodes the PCM with their OS and nothing else can communicate.
They suggested having a GM dealer reflash my PCM to stock, then HP Tuner would work.
Can anyone else confirm this? Also, will my PCM remain unlocked? The motor is in my Porsche and if it gets recoded with the stock security stuff the motor won't start...
If it just has an efi custom os then you should be able to do a full flash with hpt with a new tune into the pcm without reading it and you should be good. If it has been locked then the person who locked it is about the only person who can unlock withous going into the pcm. BUT it really depends on how the tune was done with EFI because there are certain changes that can be done with efi and the pcm not be locked but it will lock out hpt. In that case you have to flash it back stock with efi in order to use HPT on the PCM.
LS1TECH Sponsor
EFILive on the other hand cannot read out one of our LS1 custom operating systems at least not any easy way
I don't think we os mod lock our gen 4 custom operating systems though.
LS1TECH Sponsor
When reading or flashing our software will first try the known stock seed/key, if this works great it will read/flash at that time. If it doesn't work our software then trys an alternate seed/key(basically for pcm's that were tunerlocked with our software) if it doesn't read out with that secondary seed/key it means the seed key is not a known seed key and will give an invalid auth codes error.
-Bill
Since always, I constantly get customers sending in efilive custom operating systems we just don't map them. Reading them isn't an issue, mapping them out is the issue.
