obd2 port not working
ok so the other day i went to get my 01 trans am tunned and the obd2 plug wouldnt work... my guages messed up only ones working are the speedo,volt and oil pressure guages service engine light came one and check guages light. checked all fuses there all good.. idk what it could be help
Well pin 16 orange wire, is the scan tool hot. Should have 12 volts there all the time. Pin pin is scan tool ground, make sure you ground there. Then pin 5 is communication ground. check your wires and see if you have power and ground. If you do it maybe the scan tool. I know you said the fuse is good, the scan tool is powered off the cig lighter fuse.
