2000 Corvette FRC no start after reading PCM
Well I've just tried to read the PCM on my 2000 Corvette FRC and now the vehicle will not start. During the read, HP Tuners had dropped into a low speed read which had cause the entire process to take much longer than had expect, obviously. When I try to crank the vehicle, it sounds like the starter is trying to turn it over but it won't. Doesn't even sound like the engine is turning.
My first instinct is to disconnect the battery for a little bit, hook it back up then give it a shot. I had similar symptoms once before with my 2006 GTO, I did this and that fixed it. Granted, this was with a Gen IV engine, wasn't sure if the GEN III engines were any different, didn't want to dig myself into a bigger hole. Any suggestions? Thanks in advance!
