How do I turn off the rear O2 Sensors?
Old 02-02-2004, 09:18 PM
Texas_WS6's Avatar
Default How do I turn off the rear O2 Sensors?
When I use the NO2 I get a code. It is the Cat out of wake thing. I am just got my LS1 Edit. I believe what I need to change is cat test, count to pass in the engine diagnostic menue. Right now it is set to the stock setting of 550. I just want to make it to were it always passes so it can not set my SES light. What should I set it at, and do you think doing this will even stop my cats from failing while I am using the NO2?
Old 02-03-2004, 12:01 AM
Texas Terminator's Avatar
turn off your COT and your SES/codes with EDIT.
Old 02-03-2004, 06:50 PM
Texas_WS6's Avatar
Thats what I am trying to do. I have LS1 Edit and I am not sure what I need to do to turn those things off.
Old 02-03-2004, 10:17 PM
Texas_WS6's Avatar
Anyone have any ideas?
Old 02-04-2004, 02:56 PM
deezel's Avatar
To turn off COT (catalyst overtemp protection) go to the engine/test tab and check false for COT enable. For the O2 sensor tests you have to go into the engine hardware diagnostics (pull down list) and select the tests you want to disable...
Quick Reply: How do I turn off the rear O2 Sensors?
