231/237 cold idle great, hot idle ??
(1) hot idle hunts from 500-1500 rpms, have change main ve table @ 400/800/1200, have drilled TB hole to 1/16 over stock,have unplugeg TB position sensor with switch off turn switch on replug sensor, useing idler air control table in A-TAP to check IAC's which are showing 130 at idle ltrem still a little high @+ 2 ( working in IFR table to bring them down to - setting)
PLEASE explain which table and what values I need to change in EDIT
(2) have bucking & jecking if cruseing along at 35-40 mph , what should I do and where should I do it ?
Thanks for any/all replies
>>>Please<<< help Johnny
Y2K SS A4, YANK ST3500, 3.23'S,160 TS,LT'S with 3" y & SLP'S D/D, TSP's 231/237 & duel crain,ASP,
I have a bigger cam and have the same problem. We found the problem was "Warm Restart Enrichment." If you have a scanner like Atap or EFILive, you can see the AFR go rich for just a second. We (myself and GrannySShifting) played with it last weekend and was able to get it to idle around 800RPM, then work its way up to 1000RPM.
I don't know what he changed in LS1Edit. We were using version 1.21 (not 1.3) so there was no option to alter or turn this off.
First thing you need to do is drill out the TB hole bigger until you get the IAC's down to between 30-50 when the car is warmed up. Even with my smaller TR224 cam, drilling the hole out to 3/16" helped tremendously. My IAC's are right at 30 at hot idle.
Adding some timing should help also.
