DBW pedal is 100% WOT at 1/2 pedal travel
Old 01-24-2011, 10:02 AM
  #41
CalEditor's Avatar
Originally Posted by Jim_PA
I could go and pull his tune and try it, but I don't have any credits left to flash back with
Edit: Yep, it's confirmed, he has a fixed pedal. Wish I would have thought of this long ago, I wasted all my credits licensing and flashing hpt files that are of no use to me.
Send me the VIN
Dont use anymore credits. You should never have to do that anymore.
Old 01-31-2011, 01:47 PM
  #42
CalEditor's Avatar
I picked up a 03 T-body and APP Sensor to test on the PCM tonight.
Old 01-31-2011, 03:01 PM
  #43
Jim_PA's Avatar
Nice, now someone else is collecting parts to work on my problem
I still think it has everything to do with the EAP vs non-EAP pedal travel difference.
Old 02-06-2011, 07:15 PM
  #44
CalEditor's Avatar
Make sure it is wire just like this
Old 02-07-2011, 07:35 AM
  #45
Jim_PA's Avatar
The wires look good on my end, were you able to test your pedal and TB?
Old 02-07-2011, 08:07 AM
  #46
CalEditor's Avatar
I will tonight, but I made up a new calibration and it looks good. I just need to test it.
Old 02-07-2011, 11:20 AM
  #47
lt1773's Avatar
let us know the result
Old 02-13-2011, 04:48 PM
  #48
CalEditor's Avatar
TEST BIN #3
Change the file extention by removing the HPT
File Type: hpt
Old 02-13-2011, 05:25 PM
  #49
CalEditor's Avatar
Test BIN #4
relaxed DBW settings
File Type: hpt
Old 02-13-2011, 06:06 PM
  #50
CalEditor's Avatar
I had some issues pushing it into my 06 PCM. I figured it all out
Old 02-14-2011, 08:02 AM
  #51
Jim_PA's Avatar
Going to be trying them out shortly! -- Can you explain what's different between the 2?
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!
Old 02-14-2011, 08:14 AM
  #52
CalEditor's Avatar
none adjustible pedals and then 06 DBW settings on the second.
Old 02-14-2011, 09:08 AM
  #53
Jim_PA's Avatar
Well, neither of those fixed the pedal I'm probably going to just mount a new stopper on the pedal at 100% opening and bend the arm down so the pedal doesn't sit so high.
Nothing out of the ordinary here:
[PCM] P0315 - Crankshaft Position System Variation Not Learned (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (Pending) (Old) (History) (Current) (Immature)
[PCM] P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency (Pending) (Old) (History) (Current) (Immature)
[PCM] P0463 - Fuel Level Sensor Circuit High Voltage (Pending) (Old) (History) (Current) (Immature)
[PCM] P0706 - Trans Range Switch Performance (Pending) (Old) (History) (Current) (Immature)
Old 02-14-2011, 09:28 AM
  #54
CalEditor's Avatar
In the schematic above make sure that the 2 TAC motor wires are a single wire NO SPLICES
Old 02-14-2011, 10:26 AM
  #55
Jim_PA's Avatar
Well, the only thing I could realistically do is make 2 new wires and temporarily run them directly over the top of the engine from the TAC to the TB. The factory harness is all taped up and loomed.
Old 02-14-2011, 11:05 AM
  #56
CalEditor's Avatar
It worked on the bench for me.
Old 02-18-2011, 05:36 AM
  #57
Jim_PA's Avatar
Well, I guess my next step is to build a new temp. Cable to go to the throttle body, and/or try a different TB
Old 02-18-2011, 07:16 AM
  #58
Old Geezer's Avatar
Thumbs up Same here..
[QUOTE=Jim_PA;14501970]Well, neither of those fixed the pedal I'm probably going to just mount a new stopper on the pedal at 100% opening and bend the arm down so the pedal doesn't sit so high.
I have an 05 system, and the pedal to % ratio is fubar, compared to my Silve.
Am going to scan the pedal position, and move the stop...Done deal.
Old 02-18-2011, 07:27 AM
  #59
Jim_PA's Avatar
[QUOTE=Old Geezer;14521101]
As much as I dislike being defeated by something like this, it's probably what I will do with spring being right around the corner.
Old 02-18-2011, 09:14 AM
  #60
CalEditor's Avatar
Can you send me a scan
Quick Reply: DBW pedal is 100% WOT at 1/2 pedal travel
