DBW pedal is 100% WOT at 1/2 pedal travel
Old 02-18-2011, 09:23 AM
  #61
Jim_PA's Avatar
Originally Posted by CalEditor
Can you send me a scan
Can you dummy that down for me a bit? Is that something I can do with HPTuners?
I'd be more than happy to do it
Old 02-18-2011, 06:04 PM
  #62
CalEditor's Avatar
Looking for an HPT scan of the APP, TPS, and commanded Throttle angle when this occures
Old 02-19-2011, 07:11 AM
  #63
Old Geezer's Avatar
Default In my case...
[QUOTE=Jim_PA;14521137]
Originally Posted by Old Geezer
As much as I dislike being defeated by something like this, it's probably what I will do with spring being right around the corner.
I have an 05 truck pedal, with the really long pedal arm. No way would it fit in my 55, so I had cut it down a bunch. Doing that changed the ratio of pedal movement to signal level.
The pedal is still too far off the floor to be comfortable. So, I scanned the movement, and found it's at 100% far from the stop. I'll lower the pedal, and go from there w/ a relocated stop....
I've not looked at the mounting of the sensor yet. But, I wonder if the holes could be redrilled, and the entire unit rotated????
I'm thinking about the same!! Spring is already here, in GA. I need to ride!!
Old 02-23-2011, 04:23 PM
  #64
Jim_PA's Avatar
Well, something looks suspect in the scan to me. ETC Position 72%, Pedal position 20%?
Screenshot and hpl log attached.
Attached Thumbnails DBW pedal is 100% WOT at 1/2 pedal travel-capture.jpg
File Type: hpl
Old 02-24-2011, 07:04 PM
  #65
Jim_PA's Avatar
Here's an ETC scan of my stock 2004 Yukon
Attached Thumbnails DBW pedal is 100% WOT at 1/2 pedal travel-capture2.jpg
File Type: hpl
Old 02-24-2011, 09:47 PM
  #66
CalEditor's Avatar
Yukon
Truck
I will get some better pictures
Old 02-24-2011, 09:49 PM
  #67
CalEditor's Avatar
I see the issue now.
I can fix that
I will build another tune for you
Old 02-25-2011, 07:21 AM
  #68
Jim_PA's Avatar
I can fix that
'common man, the suspense is killing me Wha't the secret code that's been messing with my gas pedal?
Old 02-28-2011, 09:49 AM
  #69
CalEditor's Avatar
no need to try to run that last one.
What type of flywheel do you have? Iron?
Old 02-28-2011, 09:55 AM
  #70
Jim_PA's Avatar
It's billet steel - I sent you an email with the results from the file you sent me on Friday - pedal seems closer (might be correct), but it's throwing U0107 on start-up, and throttle motor dies at 85% TPS.
Old 02-28-2011, 10:15 AM
  #71
CalEditor's Avatar
I built it off a different T-Body setup. Wasn't thinking about it hard enough
DBW pedal is 100% WOT at 1/2 pedal travel-43567.jpg
Old 02-28-2011, 10:22 AM
  #72
Jim_PA's Avatar
Attachment 281889
Ahh OK- looks like the base of the tune was from a Corvette? I liked the fact that it seemed to be more 6-speed friendly, had M6 smoothing settings and everything.
Old 02-28-2011, 11:33 AM
  #73
CalEditor's Avatar
Not Y-body
I will look again tonight for a good starter file
Quick Reply: DBW pedal is 100% WOT at 1/2 pedal travel
