tune out rear 02 sensors
Hey guys I bought a diablo sport predator u7198 and could not figure out how to tune out the rear 02 sensors? Please any one can you please help I try to look on there but nothing! Does that tuner even do it? I was told yes so I probably was missing it! My car 02 SS a4
LS1Tech Sponsor
is it a newer one or an older one? you can tell by the revision number...
power it up, and when it's at the main menu, the revision number is at the top of the screen...
if it's an older one, it'll be a 2.xx revision - and you can find the o2 sensor stuff under Modify Tune - OBDII section...
if it's a newer one, it'll be a 9rxx revision, and you won't find any obd/o2 stuff anywhere, because all of that functionality was removed due to EPA regulations... in which case, you'll need to get a custom tune done for your car in order to get the stuff disabled... contact me if this is the case...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
if you go on the diablosport forum i have heard if you put ur tunes out there they might be able to help you and tune out the O2's for free if not monte does it for 30bucks or 100 for a full tune
