VATS & Passkey Bypass question.... ???
Location: The dirty taint of the country. ...Los Angeles
If VATS is already tuned out of the PCM but the car still won't start, is there any point in performing a Passkey Bypass from under the steering column?
PS.... Even with VATS turned off in the PCM, the security light still flashes. ... I'm just not throwing a DTC.
... Just put my OHM Meter to the key. ... 3.74 (tested 5 times) ... Is that low for these keys?
Your meter is probably showing the value in K ohms. That is 3740 ohms. That is one of the 15 possible resistor values.
http://shbox.com/1/4th_gen_tech2.html#pass_key
Problem Solved!!!... Passkey Bypass: DONE! ... So the answer to my original question is "YES"... So even if you tune VATS out, if the car won't start it IS still nessisary to perform a Passkey Bypass. ... BooYaaaa!!!
Made a Vid!
https://ls1tech.com/forums/general-m...how-video.html
Made a Vid!
