3 bar tune question with 411 pcm
Looking at running a 411 pcm and setting it up with a custom os for a 3 bar tune.
Will I be able to delete all the stock O2's and run the SD tune on it?
Can the OS support wideband data to control fuel in closed loop? Or would I just have to run open loop SD tune?
Also will a newer 1mb PCM work with a 3 bar SD tune and E85 better than the 411?
Thanks
Thanks
You can delete the O2's and run 3bar SD just fine but you don't need to delete them to run SD. You will need a custom operating system to see VE resolution above 1 bar though.
The 411 PCM's cannot use a 5v WB signal and process it natively.
No real advantage to using the 1MB PCM that I can think of off hand.
awesome, thanks. So no closed loop fueling with the wideband, thats kinda sad.
does both hptuners and EFI live have custom OS's for the extended VE and timing tables?
looks like 411 is the way to go then.
Thanks
How do you do it in HPT. Fudge IFR and VE to give higher spark table resolution and then chase all the other tables that relate to correct for it. Screw That. Yet I guess when your forced to do it because the software doesn't allow an accurate way to do it, there isn't any other options.
I'm not bitter about HPT at all. I bought it after all to unlock the stupid way HPT locks PCM's on anything you put a COS in and to tune Fords. Sold it shortly after though when I realised how much it lacked to what I already had and that their Ford support is joke compared to SCT. Hell you bought EFI LIVE, so you must feel something is missing too.
But lets not turn this into a one vs the other argument again as we already know the one that sponsors the fourm automatically has to be better and arguing any other way closes a thread.
Just facts for the OP please, which until you share how its done in HPT remains to be seen possible to the OP if he used HPT.
Those tables don't ring a bell. Is it a unique HPT name for them. It sounds more like a fuel table than a spark timing table.
I never use the Fuel Spark Correction Table as I've never found a need for it and I fail to see how the AFR spark correction table has anything to do with boost as its Axis' are EQ/RPM.
Perhaps you could screen shot the tables your on about. I don't have HPT any more and this so called demo version that is released isn't on the site.
Thanks for the info. Its kinda sad my old OBD1 set up on my typhoon can run a custom bin with extended fueling tables past 30psi as well as WBO2 feedback with desired afr tables. Seems im going backwards with this ls1 stuff.
Im probably going with efi live just for the better documentation of what can and cant be done. ( i have had a hard time finding any real info as far as PCM set up and tuning software is concerned)
7 Second Club
With that said, here is a link with a screen shot and an explanation: http://www.hptuners.com/forum/showpo...8&postcount=11
Ok I see what you guys are doing. IMO there isn't enough control doing it that way as if I'm understanding it correctly your having to alter eq to modify timing. But it appears you can't lock fuel at say 11.8 and gradually pull timing up to 3bar independently.
With that solution there simply isn't enough resolution to control enough timing increments with few fuel increments. FFS 0.05EQ steps translates into .73:1 steps in AFR. Sure it might be enough to get you by, but by my reckoning you'll be throwing in way to much fuel just to get a functioning timing table.
This on the other hand is how I do it. 10kpa increments that interpolate. Its nice.
