got some codes need help figuring out
Old 01-07-2011, 02:47 PM
jdmotox333's Avatar
Exclamation got some codes need help figuring out
one is for slow 02 bank one signal car has long tubes and the other is a clutch switch circuit malfunction any ideas what might be the problems thanks in advance the codes are p0704 and 0153
Old 01-07-2011, 03:22 PM
MM98's Avatar
Lazy driverside o2 sensor & clutch pedal postion switch.. Is your car not starting when you press down on the clutch pedal?
Old 01-07-2011, 03:25 PM
jdmotox333's Avatar
no everything works fine starts up everyday all the shifts are fine second has started to grind on some occasion but i think thats the trans itself so im gonna change the fluids here soon in the trans... what do i need another 02 sensor for the car?
Old 01-07-2011, 03:31 PM
MM98's Avatar
Weird, unless the code is referring to the ac clutch, which you're prolly not even using your ac though.. Yes, replace your o2 sensor, common for them to go out on these cars.. Im happy if I can get a set to last me a year.
Old 01-07-2011, 03:35 PM
jdmotox333's Avatar
well i burned up the drive side cause it came lose and laid on the header so yeah but so now just leaves this clutch circuit malfunction it threw me off cause its hydralic shouldnt really have any electronics except for like you said it being pushed in at start up but thats fine bump the key and starts everytime
Old 01-07-2011, 03:39 PM
MM98's Avatar
Right, its just a saftey feature so you dont throw the car forward when trying to start it while in gear.. Did your scanner give u any P codes or is it just a discription only?
Old 01-07-2011, 03:43 PM
jdmotox333's Avatar
it did just i did it yesterday and texted a friend the info but we both cleared are messages go figure lol ill prolly go back out tonight by advance and get there scanner again if no one else has any idea what this could be by then
Old 01-08-2011, 12:36 AM
jdmotox333's Avatar
Old 01-08-2011, 01:46 PM
jdmotox333's Avatar
ttt for the weekend
Quick Reply: got some codes need help figuring out
