car wont start it only cranks...
Old 01-14-2011, 03:35 PM
98hc4mula's Avatar
Default car wont start it only cranks...
hello
i have been trying to start this car and it just doesnt want to start. it started maybe about 3 times for about 10 seconds then it dies.
I tested the Drivers side coil and the pink wire has power
on the PS. the pink wire at the coil connector does not have power.
what should I be looking for. I am making sure all my grounds are connected
the 3 grds on the DS head on on. the ones on the DS block as well.
one on the PS block by the starter...
help
Old 01-14-2011, 03:38 PM
98hc4mula's Avatar
all fuses are good.
PCM bat
ENG sens
PCM IGN
IGN
STRTR???? should this power the test light with the key on the ON position?
Old 01-15-2011, 01:06 AM
98hc4mula's Avatar
any ideas.....what should I do next
Old 01-16-2011, 12:45 PM
wanger's Avatar
Don't know what car your trying to get started, but it sounds like a vats issue. If you have hp tuners, try re-linking,or disabling the vats. If you don't have it do a search to re-set it using a series of key iterations.
Old 01-16-2011, 01:02 PM
mikeyc34's Avatar
i had a friend with those symptoms and it did it off and on. i think that it was the key chip went bad or something like that. maybe try using a spare key.
Old 01-16-2011, 03:35 PM
98hc4mula's Avatar
the issue is not the grounds anymore. I figure them out last night. the issue now is that the coil pack harness at the PS is not getting juice.
Old 01-18-2011, 11:34 AM
Y2K WS6's Avatar
I have had a very similar problem, I'm quite anxious to see the problem, However this happened after I had uploaded the HP tuners real time tuning.
I have written entirely back to the stock file, and still can't get it to start.
