Pull fuses to prevent engine startup?
Old 02-10-2004, 07:39 AM
WayneSS01's Avatar
Default Pull fuses to prevent engine startup?
To prevent the engine from starting and the alarm still function.
Should I pull the PCM BAT and PCM IGN fuses while the ignition is off? Just want to add some additional temporary security.
Old 02-10-2004, 10:00 PM
cueball's Avatar
i wouldnt pull the pcm bat fuse because you will reset the pcm every time you pull it and your pcm will be relearning every time
Old 02-11-2004, 08:30 AM
WayneSS01's Avatar
Ok thanks. So just pull the PCM IGN fuse, or some other one?
Old 02-11-2004, 02:46 PM
rickou812's Avatar
I would like to know also. Would come in handy if your where to accidently spray a shot of nitrous when the motor wasn't running.
Old 02-11-2004, 04:42 PM
Bad30th's Avatar
Why not pull the fuel pump fuse ?
Bad30th
Old 02-11-2004, 06:48 PM
rickou812's Avatar
Because if you have a engine full n2o you do not want the engine to fire. pulling the fuel pump fuse would keep it from cranking up but the spark plugs would continue to fire and kaboom
Old 02-11-2004, 07:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
For security I would just pull the fuel pump relay like said above.
For nitrous,don't spray it with the engine off
Old 02-12-2004, 11:35 AM
WayneSS01's Avatar
Fuel pump thanks. I also wondered about pulling the starter relay. It is ok to pull these relays right, without causing other problems?
