ABS Problem
ABS Problem
Hope this is the right place, if not let me know. I have a 98 z28 that after having an oil pan replaced the abs system is going crazy. Anytime you touch the brakes the LOW TRAC light illuminates and the abs system is kicking back on the pedal. Even slow 5 mph rolls. After about 2 minutes of this it senses something is wrong and the ABS INOP, along with ASR OFF light comes on. Firestones screwing me and saying since the car wasnt driveable when i brought it in they cant confirm a mistake on their part. Any tips would be helpful.
Is there a reset or relearn period for these systems?
Check the wiring harness from the front wheel sensors (left and right) make sure they did not unplug anything or pinch one of the wires when they fixed the oil pan.
I don’t know if they picked up the engine or removed the cradle to fix the pan.
There are 2 wires on each side and they are twisted together.
Let us know.
Let us know.
Thanks for the reply, I actually had a GM dealership run a diagnostic on it today. Verdict is a fried ABS module. I still want to check the wheel sensor wires to be sure but I guess Ill post in the classifieds for a module
