Injectors flow rate for 1999 camaro
I need some help from someone here please.
I have a 99 PCM that is controlling a 6.0 with stock 99 injectors and stock intake. I need to find out the injector scale to input it in the tune. I came up using EC-Tune spreadsheet with a scale from 30.59-33.51 lb/hr
using the value for injector IFR of 26.4, is that the value I need to use or should I use 22 lb/hr since they flow 22 at a pressure of 43.2?
I want to make sure the values are right. the car had some 42lbs tuned into the pcm but now it has the stock 99 injectors.
thank you in advance.
David
David
