what's best tune Maf or Mafless ?
Old 01-31-2011, 06:23 AM
PONTIAC SLP's Avatar
Default what's best tune Maf or Mafless ?
hi just wondering and can't decide and what's good performance , car is 2001 Trans Am Six speed
Tune with maf or mafless ?
let's see what u think guys
thanks in advance
Old 02-01-2011, 08:01 PM
wilson34's Avatar
Looks like your running alot of motor, and depending on your cam you may have to run SD to gain driveability in all areas.
I'm about to convert my fathers C6Z06 to mafless due to the GM stage iii cam that has bucking that I can not cure in the 1800-2000rpm range due to the maf.
Old 02-01-2011, 08:11 PM
FirebirdSS's Avatar
Maf
Pros: More precise in higher rpms. Easier to tune.
Cons: Can become dirty, and Failed Maf is not necessarily common but does happen
Speed Density
Pros: Easier to get engines started with big cams. Sensors do not gum up like a mafs do.
Cons: Not as precise in upper rpm but this does not mean the tune is off, just not as accurate as a properly working maf. Overall it is harder to tune through out the rpm range.
My nuts always swing toward Speed Density, it simplify the engine.
Old 02-02-2011, 10:43 AM
Pulse_GTO's Avatar
You might have to step up to a 100mm MAF with a 454, you would probably max out the Hz limit on the stock one. Why don't you do a blend tune like it's done from the factory?
Old 02-02-2011, 11:39 AM
BOTTLE ROCKET's Avatar
Two points of reference are better than one
Old 02-03-2011, 01:06 AM
hmm thanks guys , i ordered TSP 100mm maf , how that sounds ?
Old 02-03-2011, 06:54 AM
moehorsepower's Avatar
Mine LTX, 722 RWHP, Stock MAF (De-screened) Forced Inducted. The debate goes on......
Old 02-04-2011, 07:47 AM
Q8-TECH's Avatar
its mostly personal preference and what your tuner is most comfortable with, they will both get you the same results.
for me most people with big cams i would suggest i give them a mafless tune, and for me i like SD better i feel it has better throttle response
Old 02-05-2011, 04:55 AM
khaotic's Avatar
Default Preferance
Really preferance, it has been debated alot, I run Maf on a big cam 250 duration on intake and 260 on exh. smoth idle stock maf.
Old 02-10-2011, 03:12 PM
James Linder's Avatar
IF you have a good tune MAF is always better. This is far superior to speed density unless you have a 9 second race only track car. Driving on street with speed density is just and excuse for a bad tune or a tuner who does not know what he is doing.
Old 02-10-2011, 03:26 PM
thanks again fellas !! , i'll run with TSP 100mm maf
Old 02-10-2011, 05:05 PM
ucanthangwme's Avatar
Wouldn't it also depend on the weather? I thought if you live somewhere where the weather can rapidly change, it is better to have the MAF. ??
Old 02-10-2011, 07:34 PM
FirebirdSS's Avatar
Not going to matter since Speed Density uses the temp senor as one of the main inputs.
Old 02-10-2011, 07:45 PM
little_chewy_69's Avatar
i thought sd tuning eliminates bucking and idle hunting?
Old 02-10-2011, 10:22 PM
joecar's Avatar
An SD tune that correctly models the engine (including injectors) will be immune to change of weather.
If you're going with a MAF, you still need get both the VE and MAF tables corrected.
Either way, idle tuning is still required.
Old 02-10-2011, 10:32 PM
joecar's Avatar
There are other aspects that can affect how well or not the MAF functions, things like reversion, resonance and airflow behaviour in the intake plumbing.
Old 02-22-2011, 11:52 AM
Sid447's Avatar
If anyone drove a properly set-up car either SD-OL or SD-CL they would not make this kind of ill-informed statement.
HSV GTS cars came from the factory with SD tunes.
They ran perfectly with better drivability and throttle response than maf-tuned cars from the same stable.
A properly set up tune is important whether you choose to run SD or a Maf.
Quick Reply: what's best tune Maf or Mafless ?
