Will someone take a look at my log (hpt)
My dads car is running really strange. I logged it tonight and it barely spins the tires and then runs ok, then shifts into second and all the sudden the pedal drops and the motor doesn't go anywhere. Its like its hitting traction control, but it is unplugged under the hood. It is also running 15.5* of spark WOT and getting a consistent 4KR. I beleive the KR is from the Y-pipe resting on the floor, which we will hopefully fix ASAP, but that shouldn't make the car stall more or less as soon as it goes into second gear would it? If you get out of it and then hit it again it pulls pretty good, its just if you stay in it from first..
BTW this is on a stock tune minus my fan settings and speedo recal.
I'm lost
I'm lost
I also unhooked the traction control under the hood.
The only thing I can think of is if like your saying the headers are creating such a horrible "knock" that the knock sensors are freaking out, but are they that severe??
Sound like a plan? Any tips on disabling the knock sensors temporarily to trouble shoot?
First provide some deails on the car. Why do people always ask for help and give no details on the car. The airflow in the log file histogram looks high for a stockish car. But then again we have no idea what has been done to it. Also from the log you posted the tune is not as stock as you stated. <<BTW this is on a stock tune minus my fan settings and speedo recal.>> The commanded A/F in PE in the log is not stock for a 01 F-body that the log IDs the car as. You obviously have the ability to post the .hpt tune file so why don't you? You could have something jacked up in the tune.
The car has:
UDP
LT's into stock exhaust
Stock everywhere else including lid/ filter..
EDIT: Also has a Yank SS3600 and built transmission
Unplugged Traction Control??????????
Maybe you unplugged something you shouldn't have. Evidently your car does not have the interior shut off switch on the dash like the typical LS1 FBodies from 1998 (possibly older) through 2002. I would be damn certain what I unplugged is not affecting more than the traction contol. If you have manual transmission then I am not familiar with how your car may be configured from GM - my reference is to the automatics like mine.
The car is an M6converted to A4 Btw.
I logged it again today, and it popped some codes, I'm not sure if didn't read last night or if they came today.. Im not sure what they stand for?
The P0327 code and the symptoms lead me to believe you really need to replace the knock sensor. I highly doubt a banging y-pipe is going to cause what you're talking about, I had a horrible y-pipe banging issue but it never caused a knock sensor code or caused my car to run as bad as you're describing. Sometime sensors don't go completely useless all at once, sometimes they come and go which could explain why it runs ok sometimes. Usually any sensor that throws a "circuit low voltage" code is an indication the senor is on it's last leg.
EDIT: I'd also say your [Brake] C0550 code could be a result of you unplugging the TCS. The other U codes are common when you reflash the PCM, they'll go away after you drive the car a while after tuning.
Post Your Timing Curve
Plug that thing back in under the hood and flip the switch inside
to disable TC and try this to make certain it does not change anything.
And please post your timing curve so I can see how much timing
you have dialed in across the loads verses RPM.
Please also post your MAF curve verses Hz. Are you sure your
fuel filter is not plugged up. If you let these get bad you will run lean and after enough time it will cause your fuel pump will go bad and you have to take the fuel tank off to put a new one in - what a hassle.
Banging Exhaust Pipe
Just to be clear, an exhaust pipe banging can certainly trigger the knock sensors, this is widely accepted and documented. This is because this knock is a a frequency close enough to that of the piston knock the sensor is designed to detect. These sensors are designed to detect knock so slight that you could not begin to detect it with the human ear, and the knock so loud that you can hear due to your exhaust pipe is probably causing them to go nuts with retarding your timing. Eliminate the exhaust pipe banging before jumping into any conclusions about replacing the knock sensors. Be sure and check to make certain your transmission mount is not broken because this will certainly allow the y pipe to hit the body (under driver side seat) when you get on it and torque the engine up. check with Frost and make certain the PCM you are using with the automatic that was meant for a manual will work as long as you have it programmed correctly - this is beyond my experience.
I can upload the MAf and spark curves if you really want, but they are stock 01 automatic...
Were thinking the y-pipe sitting where it does could be from terribly worn motor mounts..
We may be putting motor mounts in it, I'm not sure what else to do about the y-pipe. The same headers and y-pipe have been on two of our other cars, and neither had the clearance problem, so it has to be something about this car..
