TunerCATS issue with Read/Programming
Hi guys,
I have been trying to get TunerCATS to work for my application. I currently have 2 1995 B-Body PCMs, and I intend on reflashing one of them so it will have an M6 F-body tune (also 1995).
However, when i patch into my PCM, i get the error:
"Invalid Response from PCM"
This happens about 3/4 of the way through reading the PCM. I am using a cable purchased from ALDL cables.
has anyone else had this issue? I have followed all the guidelines set up by TunerCATS -- grounded engine, fresh battery, all programs on computer turned off, disabled internet etc. But still no dice.
I can read the VIN number information -- so i know the cable is working. Any ideas?
The car is a 1984 Jaguar XJ6, with a 1994 Camaro Z28/T56... The harness is from a 1996 Impala SS, but the pin-outs for the OBD connector are the same...
I thought you were supposed to leave off any charger because the ranges are so narrow?
Where could I find instructions on how to build a bench harness? That sounds like a good idea...
I flashed a couple today and both I had a charger on. I used to never do that but if you are using the right charger you will be ok.
I have had a few cars I had to hook a battery charger or the flash failed. That was with LS1 and LT1. They cranked and started good but the PCM voltage was low somehow.
With 94-95 PCM's you have to be very careful, because everytime you flash the PCM's memory is completely erased. If the flash proccess fails you can brick it.
Any battery charger is good, just set it at low Amp and you're good to go.
thanks guys for the suggestion -- i've also read that different settings for the COM port should be set -- baud rate higher, hardware buffer on, FIFA buffers on max. I'll try again -- hopefully i didn't brick my PCM.
