Can anyone else feel their 02's switching under part throttle?
I can actually feel the lean-rich, lean-rich, lean-rich transitions as my 02's are switching in closed loop. I can see my wideband gauge bouncing quickly between low 14's/mid 15's & the car very slightly pulsates under part throttle.
As soon as I force OL in the scanner, the car runs perfectly smooth & my wideband gauge stays right at commanded afr without all the bouncing back & forth. Is this normal? Can anybody else actually feel the 02's at work?
I'm also having the same problem! my car is pulsating between 300rpm and 1700 rpm and it keeps throwing p1133 and p1153 codes. I talked with a mechanic who used to work at a Chevrolet dealership and he said the the IAC (idle air control) motor can cause it to fluctuate because it its not reacting to the signals the pcm is sending it and allow more air in than needed therefor throwing the codes! is there any truth to this?
