VE Tuning @ 416
VE Tuning @ 416
LS3 stroker, AFR 230, ported Fast 102 & NW 102 TB, cam is 243/247 .628, AR 1 7/8 3" exhaust, C5
The injectors are modified LS3 to 48lbs, the correct data was given by the supplier & loaded into the tune.
In the lower rpm columns of the VE I've reduced the original values by on average 50% & the Cranking VE table by 70%.
This does not seem right based on the modifications to the engine & increased displacement.
I'm hoping for some experienced tuners to offer there thoughts on this, primarily if it is correct or not.
I've actually read the article which is one of the reasons I'm asking the question.
To answer your question, no I do know if the supplied data is correct. I'm not near wise enough to know that either. Another reason I'm asking the question.
The simplest solution would be install stock LS3 injectors, load the correct data & see if VE results move back. I do not have a set of LS3 injector's to try.
here's a pile of stuff on injectors and why they're important to get as perfect as possible:
http://redhardsupra.blogspot.com/200...ctors-are.html
http://redhardsupra.blogspot.com/201...-grouping.html
http://redhardsupra.blogspot.com/201...-and-4bar.html
The Offset, Short Pulse Adder & Min Injector Pulse tables were all changed as given by the supplier.
Other than the IFR which you identified being incorrect the other tables were changed previously, as you stated there would be no change in them from the previous tune.
