lsx376 e85 and pump gas
My thirdgen iroc is going in for tuning at the end of the month of april for tuning. My question is, can my car be tuned to run on pump gas and e85 gas? My current setup is a lsx376 crate motor with Cold Air Intake, longtubes, stock 42lb injectors, stock ls3 intake, a1000 fuel regulator, and a 340lph fuel pump. I believe I am using hp tuners and the car has a 411 ecm.
Actually, yes! The 411 PCM has provisions for a flex fuel sensor. Just wire it into your PCM. I just asked the same thing and was given tables and this info. I was told that the dual flash PCM is un needed in your case.
Ps why did you tell him something that isn't true when you didnt know yourself?
