TBSS misfire
Old 03-31-2011, 07:43 PM
neverenuff's Avatar
Default TBSS misfire
07 TBSS
I was on my way home the other day and my tbss started missing horribly. No issues until then. I was about 3 miles from the house so I limped it in.
Turns out the harness going to the coil pack conector got against the ac line and burnt thru the insulation on 4 wires. The wires are still in 1 piece and didnt look to be damaged very bad. I seperated the wires and taped them up to see if it would run and that didnt help. I changed all the plugs and it is still missing.
Could it have shorted out the coils? I dont know how to check them. Anything else i should look for? I havent had it on a scanner, so i dont know what codes it is throwin, but the cel is flashing.
Thanks for any help.
Old 04-03-2011, 03:53 PM
neverenuff's Avatar
codes are P0202, 204, 206, 208. injector control circuits.
and P0300 engine misfire.
Now what?????
Old 04-03-2011, 08:33 PM
neverenuff's Avatar
blew the fuse for injectors on that bank. problem fixed. thanks for the help
Quick Reply: TBSS misfire
