Diablo Sport Tuner.. 2000 Z28... Stock... Help..
Old 04-04-2011, 03:08 PM
railmule's Avatar
Default Diablo Sport Tuner.. 2000 Z28... Stock... Help..
OK just bought this camaro came with a Diablo Sport tuner,, i know nothing about this tuner... I have been searching for tunes for a 2000 ls1 for a stock car, yet i am not have much luck.. i did find this tune, would this tune be good for my car???
WOT Fuel Mixture
2K-4K +8% Rich
4K-7K +5% Rich
WOT Spark Advance
2K-4K +2% Advance in Winter (Use 1% in Summer)
4K-7K +6% Timing
Idle
Drive:w/o AC +50
Drive: w/AC =50
Park/Neutral: w/AC +100
Park/Neutral: w/o AC +100
Fan On/Off Temps for 160/180 Thermostat
Fan 1 OFF 191.x
Fan 1 ON 201.x
Fan 2 OFF 202.x
Fan 2 ON 212.x
Fuel Injector Slope
minus(-) 7
ALL Torque Settings Management
OFF
COT Temperature
585*C
*****This is all you need for an M6 (set rev settings to your comfort level)*
For A4 GTO's these are the shift settings:
Shift Time
1-2 -6%
2-3 -8%
3-4 -10%
WOT Up Shift MPH
1-2 38MPH
2-3 75MPH
3-4 123MPH
WOT Down Shift MPH
1-2 33MPH
2-3 74MPH
3-4 118MPH
WOT Up Shift RPM
1-2 5900
2-3 5900
3-4 5900
WOT Shift Pressure
1-2 +4% Firm
2-3 +6% Firm
3-4 +8% Firm
PART Throttle Shift Pressure
1-2 +6% Firm
2-3 +8% Firm
3-4 +10% Firm
if this tune would not be a good one can someone help me set my car up thanks...
Old 04-04-2011, 10:44 PM
LS1Tech Sponsor
06MonteSS's Avatar
no no no no no....
that guys post should be taken down from the gto forum... hate that....
every car is different.. even if the same make/model... what works well for their car, may not work well for yours...
shift pressure, you can set where you want, to how you like it....
if you want to raise the shift points, you can do that too, to where you want it to shift...
for fueling, timing, WOT settings... you really need to do some data logging to see what YOUR car is doing, so you can make proper adjustments...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Quick Reply: Diablo Sport Tuner.. 2000 Z28... Stock... Help..
