Finding the right BCM
Ive narrowed down my problem to the BCM and doing more research found out you cant just buy any BCM and install it on your car used or new. It has to be specific to the options your car came with from the factory. Does anyone know what BCM i would need for a 01 Z28 M6 fully loaded from the factory? There is one thats coded 1625-5931 DWM and the other is UPL or another one thats 1623-9981 KUB. If i pull out my stock BCM will it say on it what BCM i need and do i need the dealer to still to reprogram anything?
There are only 2 options for the BCM on all 98-02 f-bodies:
Part# 9353681 w/out keyless entry.
Part# 9353691 w/ keyless entry.
You HAVE to buy a new BCM, you cannot use a salvage one.. BCM's can only be flashed once to a vin. Yes, you will need to have the new one flashed to your car.
