HPT suite 2.22 install in Window 7
Old 04-25-2011, 07:09 PM
darknessxyz's Avatar
Default HPT suite 2.22 install in Window 7
I tried to install it but error message said I need .NET framework 2.0. Then I tried download it from Microsoft. It now said I already running .NET framework. Any advise?
Thanx
Old 04-25-2011, 07:11 PM
I'm running Win7 Home 64bit.
Old 04-25-2011, 07:26 PM
sjsingle1's Avatar
download the net framework distributable........its the whole file not just a download that checks your system 1st.......i think the lowest you can go is net 3.5.......any higher version is supposed to be compatible with lower versions.....and you want the x64 versions if you can find them
Old 04-25-2011, 07:32 PM
Got it working now. I just found this from HPT forum http://www.hptuners.com/forum/showthread.php?t=30495
